Anyone use dielectric grease on the mc4 connectors?
Announcement
No announcement yet.
Dielectric Grease?
Wrong stuff.
No-Ox-Id Special 2 The real issue you will have with any antioxidant compound is applying the extremely thin layer. It is more like a polish. But Samchem No-Ox-Id is what all utilities use and if applied correctly will out live you.MSEE, PE -
Originally posted by Sunking View PostWrong stuff.
No-Ox-Id Special 2 The real issue you will have with any antioxidant compound is applying the extremely thin layer. It is more like a polish. But Samchem No-Ox-Id is what all utilities use and if applied correctly will out live you.30 SW310XL SB7700
20 SW320XL SB5000Comment
Originally posted by FNG AZ View PostAhh I should have clarified.... I'm using deoxit (just a dab) on the metal parts. The grease would be for extra water proofing outside of the pins.MSEE, PEComment
Originally posted by Sunking View PostAgain there is not better product to do both jobs than NO-OX-ID. End of story period... Utilities have millions of connection in salt air environments that will outlive you. 60 years and still counting.30 SW310XL SB7700
Deoxit is GREAT stuff for electronics - and especially if you use the right formula for the right application. BUT we're talking about gear outside in very harsh environments, where the grease *in thin amounts* is really the proper stuff.
Think of it this way - would you leave a professional mixer board, even if it had been perfectly restored with DeOxit on top of your house? No, not unless you wish to do a lot of maintenance and have the can in your back pocket at all times.Comment
